What is Test Mode?
Test Mode is a feature allowing you to practice using Wyze Home Monitoring Service without worrying about alerting the monitoring center by accident.
This is especially helpful when you have just finished the setup process and want to test if the sensors or the system is working properly.
In Test Mode, all hardware and software components will work as designed except that the system will not alert the monitoring center if an alarm is triggered.
You can enter or exit Test Mode at any time from Wyze App> Monitoring Tab> Home Monitoring Settings> Test Mode
Please note:: You will need an active Home Monitoring Service Subscription to use test mode. Test mode will not dispatch Emergency Services
