How can I prevent false alarms?
We have a few suggestions to help:
  • Install the motion sensor using the instruction from the manual, especially if your family has pets.
  • Train all home members and users on how to use the system, including babysitters and visitors.
  • Secure doors and windows before arming.
  • Remember your PIN so you can disarm the alarm quickly.
  • Remember your Safe Word so that you can cancel the alarm when the monitoring center is verifying with you.
  • Periodically check if the sensors are attached to windows and doors firmly.
Please note:: Wyze is not responsible for any charges that are incurred due to family alarms and no reimbursements will be issued.
