Does Wyze Home Monitoring support entry and exit delay?
Yes, Wyze Home Monitoring supports entry and exit delays.
You can set the entry and exit delays in the Wyze app by going to the Monitoring tab > Home Monitoring Settings > Entry and Exit delays.
You can also select a silent entry/exit delay so the countdown is shown only on the app and the sense hub doesn't emit sound.
  • Live Support Hours:
