Wyze Bulb Color Specs
  Wyze Bulb Color Wyze Bulb Color BR30
Dimensions Length: 2.5"
Width: 2.5"
Height: 5.0"
Weight: 0.31 lbs
Length: 3.74"
Width: 3.74"
Height: 5.24"
Weight: 0.25 lbs
Lighting Lumens: 30 - 1100
Color Temperature: 1800K - 6500K
Color Rendering Index 90+
Lumens: 30-950
Power 12 W
Working Voltage: AC 120V~60 Hz
11.5 W
Hardware Bulb Type: LED
Bulb Shape: A19
Base Type: E26
Bulb Type: LED
Bulb Shape: BR30
Base Type: E26
Life Expectancy 25,000 hours 25,000 hours
Compatibility Android 7.0+
iOS 14.0+
Android 7.0+
iOS 14.0+
Communication Mode 802.11 b/g/n, 2.4 GHz, Bluetooth 802.11 b/g/n, 2.4 GHz, Bluetooth
Integrations Alexa, Google Assistant, IFTTT Alexa, Google Assistant, IFTTT
Operating Temperature -4°F - 104°F (-20ºC - 40ºC) -4°F - 104°F (-20ºC - 40ºC)
Weather Resistance
  • Recommended for indoor use
  • Suitable for damp locations
    • Humidity Range = 0-85%
  • Not for use in totally enclosed or recessed luminaries
  • Not for use in totally enclosed luminaries
