Wyze Bulb Color and Alexa
Wyze devices can be paired with voice assistants such as Alexa. Once set up, you can use your voice to command Alexa to control your Wyze Bulb Color.
Before setting up Alexa with your device:
  1. Download the Amazon Alexa app. (iOS/ Android)
  2. Sign in to your Amazon account.
  3. Add the Wyze Skill.
    1. Tap More > Skills & Games, search for "Wyze" and select it from the list.
    2. Tap Enable to Use.
    3. Sign in to your Wyze account to link your account.
    4. Tap Close. You're ready to use the Wyze Skill.
To pair your Wyze Bulb Color to Alexa:
If you're already using the Wyze Skill, Alexa may have already discovered your new Wyze Bulb Color. To check, go to the Amazon Alexa app and tap Devices. If it's listed, you're all set! If it's not, do this:
  1. Open the Amazon Alexa app and tap Discover Devices.
  2. Tap on your Wyze Bulb Color in the list.
  3. When the bulb is found and connected, you're all set.
Voice commands for Alexa:
  • "Alexa, turn (bulb name) off."
  • "Alexa, turn (bulb name) on."
  • "Alexa, set the (bulb name) to (percentage of brightness)."
  • "Alexa, set the (bulb name) to (color)."
  • "Alexa, set the (bulb name) to (temperature)."
  • "Alexa, set (bulb name) softer."
  • "Alexa, make the (bulb name) warmer."
  • "Alexa, set the (bulb name) cooler."
  • "Alexa, make the (bulb name) whiter."
  • "Alexa, make the (bulb name) warm white."
  • "Alexa, set the (bulb name) to daylight."
Here is a list of words you can use to change a bulb to a specific color.
Shade of White Color Temperature in Kelvin Value
warm, warm white 2200
incandescent, soft white 2700
white 4000
daylight, daylight white 5500
cool, cool white 7000
Red  Yellow Blue
Crimson Green Purple
Salmon Turquoise Magenta
Orange Cyan Pink
Gold Sky Blue Lavender
