How to turn off your Wyze Bulb Color
To turn off your Wyze Bulb Color:
In the Wyze app, tap the ON icon next to your Wyze Bulb Color. This will turn your bulb off.
But wait, there's more! Two more ways to turn off your color bulb:
  1. If you have Alexa or Google Assistant set up with the Wyze skill, tell your smart speaker to turn off your bulb.
    • Try saying "Alexa, turn off (bulb name)."
  2. Turn the light off at the switch.
    • Note: This will turn off power to the bulb, and disconnect the color bulb from the Wyze app until you turn on the power again.
