Wyze Bulb Color Features
Wyze Bulb Color is more than a lightbulb - it lets you live your life in color.
Key Features
16 Million Colors
Explore millions of rich colors and save your favorites as Scenes for quick access.
Two Versions to Choose From
Comes in a 1100 lumen A19 version and a 950 lumen BR30 version.
Music Mode
Group with Wyze Light Strip or Wyze Light Strip Pro (sold separately) to sync your lights to the beat of your favorite tracks with Music Mode.
Expanded Color Temperature Range
With a color temperature range of 1800k-6500k, you get a warmer light for improved evening light.
Extra Bright, Extra Dim
Tune it extra bright to a maximum 1100 lumens (A19 version, 75 watt equivalent) versus 800 lumens from most bulbs. It can also go dimmer than the original Wyze Bulb. Select bright, vivid colors or a dim nightlight.
Sun Match
Bring the outdoors in by having your lights automatically adjust their color temperature for optimal lighting.
High CRI
Color Rendering Index (CRI) measures how close a lightbulb’s light is to natural sunlight. A 90+ CRI rating means colors will look more natural under its light vs competitors which are often have a CRI of ~80.
Sleep Routines
Wake up or fall asleep to custom lighting routines that gradually illuminate or darken with time.
Easy Setup
Set up multiple Wyze Bulbs simultaneously with the Wyze app. No complicated WiFi switching required.
Group Control
Group multiple bulbs together to control them all at the same time or individually.
Vacation Mode
When enabled, your lights automatically turn on/off according to a variable schedule to make it appear like you’re home when you’re away.
Automations & Schedules
Schedule lights to turn on/off at specific times or use Wyze devices to trigger custom light actions.
Voice Control
Control Wyze Bulb Color with Alexa or Google Assistant.
