When setting up your Wyze Solar Cam Pan 2K, you will be required to set a Home Waypoint. This is the default viewing angle that your camera will return to when you're not viewing the livestream.
You can add up to 4 waypoints.
To add a waypoint:
- In the Wyze app, tap on your Wyze Solar Cam Pan 2K.
- Start the livestream, then tap the Edit pencil icon.
- Use the Pan controls to pan/tilt the camera to your desired view. Tap Set.
- Tap the + plus sign to add your waypoint.
To edit a waypoint:
- Tap the Edit pencil icon.
- Tap on the waypoint you want to edit.
- Tap Done to save your changes.
To delete a waypoint:
- Tap on the waypoint you want to delete.
- Tap the trash can icon to delete.
- Tap Done.
To update your Home Waypoint:
- Edit an existing waypoint or pan/tilt the camera to your desired view.
- Tap the house icon, then Continue.
To reorder your waypoints:
- Hold and drag the waypoints to your desired order.
- The Home Waypoint will not change even if moved out of position 1.
