Does Wyze Video Doorbell Pro use batteries?
Yes, the wireless doorbell uses batteries.
Yes, our wire-free doorbell is powered by internal, non-removable, lithium-ion batteries. The battery life is 3-6 months with normal use, and you can recharge the doorbell using the included USB cable.
Note: You can hardwire your Wyze Video Doorbell Pro, so you won't have to recharge the doorbell at all.
