Yes, and you can receive notifications whenever motion is detected (using the body-heat infrared sensor). With a subscription to Cam Plus, you’ll be able to configure alerts to detect people, pets, packages, and more on your Wyze Video Doorbell Pro.
- Can I use Wyze Video Doorbell Pro without the included Wyze Chime Pro?
- How do I manage automatic firmware updates?
- How do I enable VOIP calls on Wyze Video Doorbell Pro?
- How do I remove my Wyze Video Doorbell Pro?
- Does Wyze Video Doorbell Pro include a chime?
- Can I use my existing doorbell wiring?
- What is the field of view for Wyze Video Doorbell Pro?
- Do I need a technician to install the Wyze Video Doorbell Pro?
- What is the difference between Wyze Video Doorbell Pro and the Video Doorbell v2?
- How long does it take to install Wyze Video Doorbell Pro?
- See more
