Can I mount Wyze Cam Floodlight on a ceiling or overhang?
Yes, you can mount the floodlight on a ceiling / overhang or wall mount, as long as you have a junction box and a neutral wire.
To position your Wyze Cam Floodlight from an overhang:
  1. Ensure you have a functional junction box in the location you plan to use your device. If you do not have an existing junction box, please contact a licensed electrician.
  2. Remove Wyze Cam Floodlight from the box and position it with the speaker on the bottom of the base.
  3. Raise the LED lamps to the highest position first and then rotate them 180° to the lower the LED lamps.
  4. Tilt the camera slightly up so the camera is looking out and the motion sensor is facing out and downward when mounting from an overhang.
  5. Follow the standard installation process shown here.
To position your Wyze Cam Floodlight vertically from a wall:
  1. Ensure you have a function junction box in the location you plan to use your device. If you do not have an existing junction box, please contact a licensed electrician.
  2. Refer to the sticker on Wyze Cam Floodlight and rotate the camera 180° so that the speaker is at the top and the motion sensor is pointed down.
