How to charge your Wyze Video Doorbell Pro
To charge your Wyze Video Doorbell Pro:
  1. Loosen the security screw at the bottom of the doorbell using the provided screwdriver.
  2. Remove the backplate of your doorbell by sliding the backplate down then pulling it away.
  3. On the back of the doorbell, open the black rubber flap labeled MicroUSB.
  4. Insert the provided MicroUSB charging cable into the doorbell and then insert the USB end into an adapter (not included) and into a power outlet.
Note: It'll take about 4 hours to charge from 0-100%.
