Sharing Wyze Home Monitoring with Others
Sharing your Wyze Home Monitoring service will give invited members access to your home monitoring. They'll have access to the Monitoring tab in the Wyze app, be able to check Monitoring events, and receive SMS from Noonlight when the primary user is unavailable.
They will also be able to arm and disarm the system from the Wyze app.
Heads up 💡 : Shared users cannot view your designated Security Cameras or modify your settings.
To share with an existing Wyze user:
This user is someone who not only has a Wyze account, but who you've shared either a device or service with before. This step edits those permissions:
  1. In the Wyze app, tap Monitoring.
  2. Scroll to the bottom of the Monitoring screen and tap Home Monitoring Settings.
  3. Tap People > Add People.
  4. Enter their email address and tap save.
Once you tap Update, the existing user will receive an app notification that'll redirect them to the shared page. Note: If the user already has Wyze Home Monitoring, they will not be able to accept the share.
To share with a new Wyze user:
  3. Tap People, then tap Add People.
  4. Enter the user's email address on the New Share page, then tap Share.
Once you tap Share, the existing user will receive an email prompting them to sign up and download the app to accept your invitation.
To add an emergency contact:
From the People screen above, tap Emergency Contact > Add Emergency Contact.
Once the shared user accepts your invitation, they will only receive a text message in case of an emergency where Noonlight cannot get in touch with the primary user.
👉 Please note: Emergency contacts only receive a text message in case of emergencies and they cannot arm/disarm the system.
To add an Additional Pin:
  3. Tap Pin & Safe Word > Additional PINs > Add Additional PIN.
  4. Create a name for your PIN, and tap Next.
    • Name the PIN to the person who's using it.
  5. Enter a 4-digit PIN for this person, tap Save.
    • This PIN will not be visible once you save it, so remember it!
A PIN is used to arm and disarm your system. You can have one General Pin and up to 10 Additional PINs, which you can provide to your shared user(s).
Additional Notes:
  • Wyze Home Monitoring cannot be shared with someone who already has the service.
  • We do not support multiple homes on one account. If you have multiple homes, you'll need a separate Wyze Account with a new Wyze Home Monitoring subscription.
  • You can also share Wyze Home Monitoring from your account. In the Wyze app, tap Account > Sharing to edit their permissions.
  • Upon canceling your service, shared users will be removed from the Shared Accounts page.
