Can I mount Wyze Gun Safe?
Yes, mount Wyze Gun Safe with the included mounting screws.
Wyze Gun Safe can be mounted for storage using the included mounting screws. Find the two pre-drilled holes inside the safe, and use the screws to mount the safe to a flat surface.
Note: Before mounting your Wyze Gun Safe, set it up in the Wyze app!
To mount Wyze Gun Safe:
  1. Check your mounting location and make sure:
    • The mounting surface is flat.
    • There is enough clearance for the lid to fully open.
  2. Position the safe at your mounting location.
  3. Find the pre-drilled holes on the bottom of the safe and use a pencil to mark the holes for drilling.
  4. Drill plot holes.
  5. Position the safe in place and install the mounting screws through the safe and into the plot holes.
  6. Tighten the screws to complete installation.
