Wyze Gun Safe Installation Guide
Before mounting your Wyze Gun Safe, check out the Wyze Gun Safe Setup Guide to get started.
To install Wyze Gun Safe:
  1. Check your mounting location and make sure:
    • The mounting surface is flat.
    • There is enough clearance for the lid to fully open.
  2. Position the safe at your mounting location.
  3. Find the pre-drilled holes on the bottom of the safe and use a pencil to mark them.
  4. Drill plot holes.
  5. Position the safe in place and install the mounting screws through the safe and into the plot holes.
  6. Tighten the screws to complete installation.
