Wyze Gun Safe Important Safety Warnings
You can also find these safety warnings in the Quick Start Guide attached, and in the box.
  1. Do not store loaded guns in Wyze Gun Safe. Storing a loaded gun could lead to accidental discharge of the gun, which could result in serious personal injury, death or damage to nearby property, including property stored within the safe.
  2. Complete device setup and test your code and fingerprint several times before securing a gun in the safe. Allowing unintended users to access a gun could lead to the accidental discharge of the gun, which could result in serious personal injury, death or damage to nearby property, including property stored within the safe.
  3. Safeguard access to your backup keys, access code, and Wyze app. Failure to safeguard access to your backup keys, access code, and Wyze app could result in unauthorized access to the safe any gun stored within it. Allowing unintended users to access a gun could lead to the accidental discharge of the gun, which could result in serious personal injury, death or damage to nearby property, including property stored within the safe.
  4. Always check to make sure the door has fully latched when closing. The lid requires a firm press to lock. Failure to properly close Wyze Gun Safe could lead to unauthorized access to the safe and any gun stored within it, which could lead to the accidental discharge of the gun, which could result in serious personal injury, death, or damage to nearby property.
  5. Do not place or store the backup keys inside the safe at any time. These keys will open the safe if you lose your access code or the battery fails. Inability to open Wyze Gun Safe could result in inability to access access the contents of the safe during an emergency.
  6. Keep Wyze Gun Safe out of reach of children and pets. Wyze Gun Safe is not a toy. Never allow children to play with Wyze Gun Safe. Doing so could result in serious personal injury. Wyze Gun Safe contains small parts that may present a choking hazard. Also, do not allow children to access Wyze Gun Safe through the Wyze app or program their fingerprints to open the safe. Allowing children access to Wyze Gun Safe could result in them gaining access to any gun stored within the safe, which could lead to an accidental discharge of the gun resulting in serious personal injury, death or damage to nearby property, including property stored within the safe. Failure to keep pets away from Wyze Gun Safe could result in the pet being injured.
  7. Do not get Wyze Gun Safe wet. Wyze Gun Safe is not waterproof. Do not get it wet. Only operate Wyze Gun Safe with clean, dry hands. Clean only with a damp cloth. If your Wyze Gun Safe gets wet, it could short out the batteries, which may cause electric shock, fire, or smoking, which could result in serious personal injury, death, or damage to nearby property, including property stored within the safe. It could also cause the fingerprint sensor and keypad to no longer work, which could cause you to be unable to access the contents of the safe in an emergency.
  8. Do not operate or store Wyze Gun Safe where the temperature is hotter than 122°F (50°C). Use or storage of Wyze Gun Safe in environments hotter than 122°F (50°C) could cause Wyze Gun Safe to overheat, catch fire, explode, or smoke, which could result in serious personal injury or death. It could also cause other damage to the safe or nearby property, including property stored within the safe. Damage to Wyze Gun Safe could also prevent it from opening in an emergency. Wyze Gun Safe is not fireproof.
  9. Do not operate or store Wyze Gun Safe where the temperature is colder than 14°F (-10°C). Using or storing Wyze Gun Safe in environments colder than 14°F (-10°C) may cause Wyze Gun Safe to fail to open, including in an emergency.
  10. Do not attempt to remove, repair, modify, or perform maintenance on any part of Wyze Gun Safe except to change the batteries. Wyze Gun Safe does not contain any user serviceable parts. Attempting to remove, repair, modify or perform maintenance on any part of Wyze Gun Safe except to change the batteries, could result in an electric shock to you. It could also lead to damage to Wyze Gun Safe, which could result in overheating, fire, explosion, electric shock, or smoking, which could cause serious personal injury, death, or damage to nearby property, including property stored in the safe. Damage to Wyze Gun Safe could also allow unauthorized access to the guns stored within it, which could result in accidental discharge of a gun, which can cause serious personal injury, death, or damage to nearby property, including property stored within the safe.
  11. Stop using Wyze Gun Safe immediately if any part is damaged. Inspect Wyze Gun Safe for damage regularly. If you suspect any part is damaged, discontinue use immediately. Continuing to use Wyze Gun Safe if any part is damaged may cause overheating, fire, electric shock, or smoking, which could result in serious personal injury. It could also result in other damage to Wyze Gun Safe or nearby property, including property stored in the safe. Damage to Wyze Gun Safe could allow anyone with physical access to the safe to access a gun stored within it. Allowing unintended users to access a gun could lead to the accidental discharge of the gun, which could result in serious personal injury, death or damage to nearby property, including property stored within the safe.
  12. Do not burn, break, gouge, puncture, crush, drop, or otherwise damage Wyze Gun Safe. Damaging Wyze Gun Safe may cause overheating, fire, electric shock, or smoking, which could result in serious personal injury or death. It could also cause damage to Wyze Gun Safe, the contents of the safe, or nearby property. Damage to Wyze Gun Safe could also allow anyone with physical access to the safe to access a gun stored within it or prevent you from accessing the contents of the safe in an emergency. Allowing unintended users to access a gun could lead to the accidental discharge of the gun, which could result in serious personal injury, death or damage to nearby property, including property stored within the safe.
  13. Use only new batteries and do not mix different types of batteries. Use of old batteries could cause the safe to fail to open. Mixing old batteries with new batteries could cause the batteries to over-discharge, leak, explode, or catch fire, which could result in serious personal injury, death, or damage to nearby property, including property stored in the safe. Mixing different types of batteries (e.g., lithium- ion and nickel-metal hydride batteries) could cause the batteries to over-discharge, leak, explode, or catch fire, which could result in serious personal injury, or death. It could also cause other damage to the safe or nearby property, including property stored in the safe. If battery leakage occurs, avoid contact with skin, as the leakage could cause burns or irritation. If skin contact occurs, immediately wash thoroughly with soap and water. If it gets in your eyes, immediately flush thoroughly with water and seek medical attention, as it could cause serious injury.
  14. Keep the batteries out of reach of children. Four AA batteries power Wyze Gun Safe. Secure the batteries used for Wyze Gun Safe in a place that children cannot access. If swallowed, batteries can lodge in a child’s throat and cause them to choke or suffer from chemical burns, which can cause serious personal injury or death. If you suspect that a child has swallowed a battery, seek immediate medical attention.
FOLLOW ALL APPLICABLE LAWS
Many jurisdictions have laws related to the licensing, storage, and use of firearms. You must be familiar with and follow each and every applicable law. Failure to follow applicable laws could result in criminal or civil liability.
