Wyze Indoor Cam Pan Connectivity Troubleshooting
Problem
My Wyze Indoor Cam Pan shows offline in the Wyze app, loads slowly, or disconnects frequently.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    1. In your Wyze app, navigate to the Account tab > tap About.
    2. Your current app version will be listed beneath the Wyze logo.
    3. Compare your app version to the latest app version listed on our Release Notes & Firmware page.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Indoor Cam Pan’s firmware is up to date.
    1. You can check this by going to the Account tab > Firmware Update.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Confirm whether the status light is on.
  4. Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  5. Confirm that the camera is connected to a 2.4 GHz Wi-Fi network and that the network is functioning normally.
    • Wyze Indoor Cam Pan is not compatible with 5 GHz Wi-Fi networks.
  6. Try moving the camera closer to the router.
  7. Reboot the Wi-Fi router.
  8. Power cycle Wyze Indoor Cam Pan.
    1. Unplug the camera from its power source for 5-10 seconds, then plug it back in.
  9. Factory reset the camera and then set it up as new.
    1. Remove any microSD card that is inserted into the camera.
    2. With the camera powered on, manually adjust the camera lens so that it is pointing up.
    3. Below the camera lens, press and hold the setup button for 10 seconds until the status light on the front of the camera turns solid red.
    4. Once the status light starts flashing red, set up the camera as new.
