Cloud CVR will remain active on the attached camera.
Cloud CVR is a separate, paid add-on that's attached to your camera. As long as you have an active Cam Plus, Cam Unlimited, or Cam Unlimited Pro plan, Cloud CVR will stay active even if you switch between plans.
Important: If you switch to a security plan that is not Cam Plus, Cam Unlimited, or Cam Unlimited Pro OR cancel your plan, Cloud CVR will be automatically cancelled on the same date.
