Can I add Cloud CVR to a shared camera?
Only if you are the camera's primary owner, and it is compatible.
If you are the camera's primary owner with an eligible subscription, and the camera is compatible, you can add Cloud CVR to your camera.
Note: Cloud CVR is only supported on Wyze Cam v3, Wyze Cam v3 Pro, Wyze Cam v4, and Wyze Cam Pan v3.
If you are a shared user and a camera has been shared with you, you cannot add Cloud CVR to that shared camera. However, you can still view the continuous cloud recordings from that camera.
