The Ambient Light settings aren’t working for my Wyze Bulb Cam Pan Color.
Problem
Your Wyze Bulb Cam Pan Color is not adhering to the Ambient Light settings.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Bulb Cam Pan Color’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on
  4. Verify that the Bulb Settings are set correctly.
    1. Navigate to the camera’s settings > Bulb Settings.
    2. Tap Single Mode.
    3. Tap Ambient Light.
    4. Toggle on Ambient Light.
    5. Under Preset Mode, select Always On.
    6. Under Adjust Brightness and Colors, adjust the slider bar to 100%.
    7. Under Ambient Light Schedule, tap Schedule.
      1. Set a different schedule to clear any stuck settings, then set it back to the preferred timeframe.
      2. Test the camera during the set timeframe.
    8. Once Always On is determined to be working, select an alternate Preset Mode, if desired.
      • Note: Firefly Breathing Light and Breathing Light are only available when the Bulb Settings are set to Single Mode. They are not available for Link Mode.
  5. Verify that there are no Automations set up that could be causing interference.
    1. Navigate to the Home tab of the Wyze app, tap Automations.
    2. Note: We recommend deleting any Automations and then adding them back one by one while testing.
  6. Confirm that there are no shared users adjusting the lights.
  7. Power cycle the camera.
    1. Manually turn off the socket via the light switch for 10 seconds, then turn it back on.
  8. Factory reset Wyze Bulb Cam Pan Color.
    1. Remove any microSD card inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera like new.
