Wyze Bulb Cam Pan Color is rotating by itself.
Problem
My Wyze Bulb Cam Pan Color is rotating by itself – I’m not doing anything or changing any settings.
Note: Wyze Bulb Cam Pan Color resets, it will rotate while initializing.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Bulb Cam Pan Color’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Turn off Smart Track.
    1. Under the camera’s live stream, swipe left/right on the toolbar to find Smart Track.
    2. Tap to turn it on/off.
      • The icon will be grey when turned off.
  4. Turn off Pan Scan.
    1. Under the camera’s live stream, swipe left/right on the toolbar to find Pan Scan.
  5. Disable any Detection Zone.
    1. In the camera’s settings, tap Detection Settings > Detection Zone.
    2. Toggle off Detection Zone.
    3. Note: If the camera’s view is adjusted while a Detection Zone is enabled, the camera will automatically return to its original position after 15 seconds of being idle.
  6. Check if there are any shared users adjusting the camera.
    1. Navigate to the camera’s settings > Sharing.
    2. Temporarily remove shared users, if needed.
  7. Power cycle the camera.
    1. Manually turn off the socket via the light switch for 10 seconds, then turn it back on.
  8. Factory reset Wyze Bulb Cam Pan Color.
    1. Remove any microSD card inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera like new.
