My Wyze Bulb Cam Pan Color’s Waypoints are not accurate.
Problem
Your Wyze Bulb Cam Pan Color is not adhering to the designated Waypoints.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Bulb Cam Pan Color’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Ensure Pan Scan is turned on.
    1. Under the camera’s live stream, swipe left/right on the toolbar to find Pan Scan.
    2. Tap to turn it off/on.
      • The icon will be green when turned on.
  4. Disable any Detection Zone.
    1. In the camera’s settings, tap Detection Settings > Detection Zone.
    2. Toggle off Detection Zone.
    3. Note: If the camera’s view is adjusted while a Detection Zone is enabled, the camera will automatically return to its original position after 15 seconds of being idle.
  5. Calibrate the camera.
    1. In the camera’s settings, tap Pan Cam Controls.
    2. Next to Calibrate Position, tap Calibrate.
    3. Wait for the calibration to complete before exiting that screen.
    4. Note: Ensure there is nothing impairing the camera’s ability to move, including the power cable.
  6. Adjust the Waypoints.
    1. Under the camera’s live stream, swipe left/right on the toolbar to find Pan Control.
      • If Pan Control was already selected, that button will change to Events, and there will be a directional pad on the screen to adjust the camera’s position.
    2. Tap the pencil icon to edit existing Waypoints.
    3. Remove any existing Waypoints, and add them back one at a time, testing between each one.
  7. Power cycle the camera.
    1. Manually turn off the socket via the light switch for 10 seconds, then turn it back on.
  8. Factory reset Wyze Bulb Cam Pan Color.
    1. Remove any microSD card inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera like new.
