My Wyze Bulb Cam Pan Color is missing or not recording Events.
Problem
My Wyze Bulb Cam Pan Color is not recording any motion or sound-triggered events, is missing events, or is not sending me any notifications.
Note: An active subscription to a Wyze Service is required to receive cloud Event videos.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Bulb Cam Pan Color’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Verify that Location Permissions are enabled for the Wyze app in the phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS users, make sure that Precise Location is turned on.
  4. Ensure the camera is set to record correctly.
    1. In the Wyze app, navigate to the camera’s settings > Event Recording.
    2. Enable Motion, then select All Events.
      1. For sound-triggered recordings, enable Sound.
    3. Tap Customize Detections.
    4. Next to Other Motion, ensure that the boxes are checked for both the Tag and Notify columns.
      1. For sound-triggered recordings, ensure that the boxes are checked for both the Tag and Notify columns next to Other Sounds.
    5. Attempt to trigger the camera by creating movement in front of the device.
      1. For sound-triggered recordings, attempt to trigger the camera by creating sound near the device.
    6. Note: For Wyze Services users, once recordings for Other Motion are being generated, you can select the desired AI recordings by checking the other options in the Tag and Notify columns under Motion.
      1. For sound-triggered recordings, once recordings for Other Sounds are being generated, you can select the desired AI recording options under Sound.
  5. Verify that the Detection Settings are set correctly.
    1. Navigate to the camera’s settings > Detection Settings.
    2. Under Motion Sensitivity, adjust the slider bar to the highest setting..
    3. Under Sound Sensitivity, adjust the slider bar to the highest setting.
    4. Tap Detection Zone and toggle it off while testing.
  6. Check that Notifications are set correctly.
    1. For the camera:
      1. Navigate to the camera’s settings > Notifications.
      2. Enable Notifications.
      3. Note: Tap Manage to be taken back to the screen to customize the Notify column for your recordings.
    2. For the Wyze app:
      1. Navigate to the Home tab of the Wyze app.
      2. Tap Account > Notifications > Push Notifications.
      3. Toggle on Push Notifications.
    3. For the mobile device:
      1. Navigate to the device’s settings.
      2. Enable notifications for the Wyze app.
  7. Verify that there are no Automations set up that could be causing interference.
    1. Navigate to the Home tab of the Wyze app, tap Automations.
    2. Note: We recommend deleting any Automations and then adding them back one by one while testing.
  8. Power cycle the camera.
    1. Manually turn off the socket via the light switch for 10 seconds, then turn it back on.
  9. Factory reset Wyze Bulb Cam Pan Color.
    1. Remove any microSD card inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera like new.
