Wyze Bulb Cam Pan Color MicroSD Card Troubleshooting
Problem
You cannot view microSD card recordings, cannot record to the microSD card, or your Wyze Bulb Cam Pan Color cannot detect the microSD card.
Troubleshooting
  1. Confirm that the Wyze app is up to date.
    4. If you find that your Wyze app is out of date, head over to your mobile device’s app store and update the Wyze app.
  2. If possible, check that Wyze Bulb Cam Pan Color’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Ensure that the microSD card is properly inserted into the device.
    1. Remove the microSD card and then reinsert it into the camera.
    2. Wait for about 5 seconds until there is a "ding ding" sound.
    3. If no sound is heard, reinsert the microSD card or, if possible, insert a different microSD card into the camera.
  4. Ensure that the selected playback time is correct.
    1. In the Wyze app, navigate to the camera’s live stream > SD Card.
    2. Under GO LIVE, select the date to view footage from.
  5. Ensure that the MicroSD Card settings are correct.
    1. Navigate to the camera's settings > MicroSD Card.
    2. Enable Record to MicroSD Card and select Record Continuously.
  6. Format the microSD card.
    • To format the microSD card through the Wyze app:
      1. In the camera’s settings, tap MicroSD Card > Format.
      2. Wait for about 30 minutes to check if there is any footage.
    • To format the microSD card through a computer, follow the steps in How to Format your MicroSD Card.
  7. Power cycle the camera.
    1. Manually turn off the socket via the light switch for 10 seconds, then turn it back on.
  8. Factory reset Wyze Bulb Cam Pan Color.
    1. Remove any microSD card inserted into the camera.
    2. With the camera powered on, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera like new.
