My Wyze Bulb Cam Pan Color's panning view is limited.
Problem
Your Wyze Bulb Cam Pan Color's panning view is limited or cut off. When you pan the camera, the view may face a wall or other obstacle.
Troubleshooting
The socket where you installed your camera determines its default position and panning area. You can use the socket adapter included with your camera to center the camera's view.
If you don't have the socket adapter installed yet:
  1. Install the socket adapter:
    1. Turn off power to your Wyze Bulb Cam Pan Color.
    2. Unscrew your bulb cam pan. Be careful, it may be hot!
    3. Attach the socket adapter to the bulb cam pan.
  2. Reinstall the bulb cam pan and adapter in the socket.
  3. Turn on power to your Wyze Bulb Cam Pan Color.
  4. Wait for the camera to reconnect in the Wyze app.
  5. Calibrate your camera:
    1. In the Wyze app, remove all Waypoints, then tap Calibrate Motor.
  6. Turn off Smart Track if it's enabled:
    1. In the menu bar, tap Smart Track.
  7. Manually adjust the camera's view:
    1. While viewing the livestream in the Wyze app, push up on the camera and rotate it.
    2. Confirm that the view is centered.
    3. Release the camera to lock it in position.
  8. Recalibrate your camera and set your Waypoints again.
If you already have the socket adapter installed:
  1. Calibrate your camera:
  2. Turn off Smart Track if it's enabled:
  3. Manually adjust the camera's view:
  4. Recalibrate your camera and set your Waypoints again.
