I was locked out while installing my Wyze Lever Lock
Problem
You closed the door before completing the setup process in the Wyze app for Wyze Lever Lock and are now locked out.
Troubleshooting
  1. Try using the included physical key to unlock the door.
    • The keyhole is located under the rubber cover on the top of the exterior assembly.
  2. Use the emergency power port to reboot the lock and enter pairing mode.
    • The emergency power port is located under the rubber cover on the top of the exterior assembly.
    • The emergency power port requires a USB-C cable (not included).
  3. Attach the other side of the USB-C cable to a power bank or to your mobile device.
    • Note: Most Android devices and iPhone models 15 or newer should support using the phone as a power bank.
  4. Once the lights begin pulsing white, walk through the setup process in the Wyze app, or follow the steps in Wyze Lever Lock Setup Guide.
