Wyze Lever Lock Setup Guide
Before you setup your Wyze Lever Lock:
  1. Make sure you are connected to data or Wi-Fi (this is only for the initial pairing with the Wyze app).
  2. Enable BluetoothⓇ on your mobile device.
    • If you’re on an iOS device, check that your Location Permissions are also enabled.
    • If you’re on a device using Android 12+, check that your Nearby permissions are also enabled.
    • Make sure that you are in BluetoothⓇ range for connection (16 feet or less).
To set up your Wyze Lever Lock:
  2. On the Add menu, tap Device > Home > Wyze Lever Lock.
  3. If you’ve already installed your Wyze Lever Lock on your door, tap Skip to skip installation.
    • If not, tap Next to install your device.
  4. Tap Next to continue pairing to the Wyze app.
  5. Press and hold the RESET button on the lock for 8 seconds.
    • The keypad will pulse white.
  6. In the Wyze app, check the box next to "It said, Ready to connect", then tap Next.
  7. If BluetoothⓇ hasn't already been enabled, you'll be prompted to allow BluetoothⓇ and Location access. Tap Next.
    • If BluetoothⓇ and location access have already been enabled, it will skip automatically.
  8. The app will automatically search and connect to your Wyze Lever Lock.
  9. If you have a Wi-Fi network that you'd like to connect to, tap Yes.
    • If you want to connect to a different network, tap No, I Will Connect Manually.
  10. Select your 2.4 GHz Wi-Fi network and enter your network password. Tap Next.
    • Tap the icon next to the text field to double-check your password.
  11. Name your Wyze Lever Lock using the text field, or by choosing one of the preset suggestions, then tap Finish.
  12. Next, follow the in-app steps to create your Access Code and add your fingerprint.
  13. You're all set! Tap Done.
