Wyze Lever Lock Installation Guide
Installing your Wyze Lever Lock on a compatible door is easy. You remove your existing lock, put your new lock in place, then set it up in the Wyze app.
Important: Make sure you have the set of physical keys on your person during installation. If the door is closed before you've inserted the batteries and set up the device in the app, you could be locked in or out.
Follow along in the video below:
