Most likely, if you're in the US.
Wyze Lever Lock is compatible with most single-bore US doors (with a thickness of 35 mm-55 mm). Some doors may require drilling, chiseling, or extra tools if they are not standard US doors.
Wyze Lever Lock is not recommended if:
- Your door has a deadbolt.*
- Your door is too thin, with a thickness < 35 mm.
*If your door has a deadbolt (or a hole for one) this likely won't work. The deadbolt must sit below the lever or at least 5 5/16 inches above it. Otherwise, the deadbolt’s keyhole and the lock’s USB-C port will be blocked.
The video below applies to Wyze Lever Lock, Wyze Palm Lock, Wyze Lock Bolt and Wyze Lock Bolt v2.
