Understanding your Wyze Lever Lock's Status Lights
You’ll find the status lights on the front of your Wyze Lever Lock. No light? Make sure all 8 AA batteries are properly inserted.
️⚡ All Wyze devices have a handy status light that helps determine what state the device is in.
Wyze Lever Lock Status Light Guide
Wyze Lever Lock Status Lights: After Setup
  • Pulsing white – The device is ready to connect.
  • Flashing white – The lock has been successfully unlocked.
  • Quickly flashing red – The lock failed to unlock.
  • Flashing red for 3s – The door lock is not working properly.
  • Battery indicator flashing red for 5s – Door lock battery level is below 20%.
Note: Wyze Lever Lock's keypad doubles as its status light. The battery indicator is below the keypad.
