Grip-to-unlock fingerprint access with Wi-Fi Connectivity.
Why we're turning up for Wyze Lever Lock:
- Grip-to-unlock fingerprint access. Unlock the moment you grab the handle. Advanced biometric technology continuously learns and adapts with every use for faster, more reliable recognition.
- Built-in Wi-Fi for remote control. Integrated Wi-Fi enables remote access, user management, and lock monitoring—no extra hub required.
- AI Self-Learning Fingerprint Scanner. Our AI-powered scanner logs pressure, angle, even tiny skin shifts with every scan. The more you use it, the better it gets.
- Up to 50 fingerprints and 50 passcodes. Register up to 50 fingerprints and 50 passcodes per lock, enough to give every everyone their own unique access—no shared keys required.
- Easy installation with quick left/right hand conversion. Simple to install and easy to switch between left-hand and right-hand lever configurations.
- Low-profile premium design with a hidden keypad. A sleek, low-profile dark metal finish both inside and out. The premium surface keeps the keypad hidden when not in use.
- Long Battery Life. Enjoy up to 12 months of battery life (batteries included).
- IP54 Weather-Resistant and ANSI/BHMA3 Certified. This lock has been tested, slammed, twisted and splashed thousands of times to make sure it can handle real life.
- Type-C Emergency Power Port. If the batteries die while you're away, the USB-C port allows for a charge from a power bank so you can enter your access code for entry.
