Using the Blink feature with Wyze Bulb Color
Have your Wyze Bulb Color (and Wyze Light Strip and Wyze Bulb White) blink in color with an Automation!
Want your lights to blink green when you receive a package, or blink blue when someone rings your Wyze Video Doorbell? Try this automation:
  2. On the Add menu, tap Automation > Device & Service Trigger.
  3. Tap the plus sign + next to Name (Optional).
    • Give the automation a name (ex: Door opens, lights on) and tap Save.
  4. Tap the plus sign + next to Device & Service Trigger.
    1. Tap your Wyze Bulb Color > Color Blink.
      1. Select the color temperature you'd like on the scale.
      2. Tap Save.
      3. Tap the plus sign + again to add other bulbs or light strips to the Automation, or continue below.
    1. Tap Time if you'd only like this automation active at a specific time of day.
      • Select your Start Time and End Time and any repeats.
  5. Tap Save.
