More Wyze Cam v3 Troubleshooting
How to power cycle your Wyze Cam v3
To power cycle your Wyze Cam v3:
  1. Unplug the camera from its power source. This can be done either from the power outlet, or from the camera itself.
  2. Allow 5-10 seconds to pass for the camera to completely discharge.
  3. Plug the camera back into the power source and allow it reinitialize.
Additional Note:
Power cycling refers to fully powering an electronic device off, usually disconnecting it from any source of power. This is a useful troubleshooting tool because it helps reset the device and its connections.
My Wyze Cam v3 Event videos have no sound.
Problem
Your Wyze Cam v3 Event videos and recordings are silent and have no sound / audio.
Troubleshooting
Make sure that Record Sound is turned on in your Wyze Cam v3's settings.
  1. In the Wyze app, tap on your camera and let the live stream load.
  2. Tap on the Settings gear, then Advanced Settings.
  3. If the Record sound option is toggled on, tap to toggle off then back on.
  4. If the Record sound option is toggled off, toggle the switch on.
  5. If there is still no sound on the recordings, factory reset the camera and set up the camera again.
There's static noise when viewing Wyze Cam v3's Live stream.
Problem
There is a static, crackling noise when viewing / listening to Wyze Cam v3's Live stream.
Troubleshooting
  1. Check that your Wyze app and firmware are up to date.
  2. Power cycle the camera by unplugging it from power, then plugging it back in.
  3. Try to factory reset your camera.
  4. Try to flash the firmware to an earlier version if you have a 32 GB microSD card available.
Does my Wyze Cam v3 need to be set back up after being moved?
Only if your Wi-Fi network changes.
If you unplug your Wyze Cam v3 then plug it in again in the same Wi-Fi environment your camera will automatically reconnect to the W-iFi network. You do not need to re-enter the Wi-Fi information or set your camera again, but it may take a few minutes for your camera to reconnect.
If your Wyze Cam v3 doesn't automatically connect to the Wi-Fi network, you can follow the same steps you used to set up your camera to add it back to the Wyze app.
  1. Open up the Wyze app and tap the + plus sign icon in the top left.
  2. Tap Add Device > Cameras.
  3. Select the device you want to add.
  4. Follow the steps in the app to set up the camera again.
  5. If you are having trouble with the setup process view our Setup Guide.
Note: As long as you add the camera to the app logged into the same Wyze account as it was before, you will still be able to view and access the same event videos stored on the Cloud.
No audio when viewing a Wyze Cam v3 video on a computer (not Wyze Web View)
If you view a video created by a Wyze Cam v3 on a computer, you may not hear audio depending on the media player you are using. Windows' default media player does not have the proper audio codex, but this can be easily remedied by downloading and installing VLC Media Player and using VLC Media Player to view your videos.
You can find VLC's official website here: https://www.videolan.org/vlc/
Can't find or stream RTSP
Wyze Cam and Wyze Cam Pan do not come with RTSP by default. To use RSTP you need to install a different version of our firmware.
Read this article to learn more about what RTSP is and how to use it with your Wyze Cam using an optional firmware.
What ports are necessary for Wyze Cam v3 to operate?
In most cases, home users will not need to manually change ports. If you are on a business/enterprise network your IT department can manually open the ports needed.
Here is a list of the necessary ports:
Port
What it does
What it's used for
TCP: 80
Local time lapse download
Timelapse
TCP: 123
Internet time check
Confirming the camera's time zone
TCP: 443
Cloud data transfer
Uploading Events
TCP: 8443
Cloud API
Keeping the connection with Cloud server
TCP: 8605
Upgrade package download
Firmware Upgrades
TCP: 10001
P2P streaming connection
Local live streaming over Wi-Fi
TCP: 10002
LAN firmware upgrade
Firmware Upgrades
TCP: 22345
TCP control
Making sure the connection stays open when viewing the Live Stream
UDP: 80
Heart beat & streaming data
For all UDP ports: Loading the Live Stream and keeping the connection between camera and server even when it's not actively being used
UDP: 443
