More Wyze Cam Pan v2 Troubleshooting
My Event videos have no sound on Wyze Cam Pan v2.
Problem:
Your Event Videos and recordings are silent and have no sound / audio.
Troubleshooting
Make sure that Record Sound is turned on in your camera's settings.
  1. In the Wyze app, tap on your camera and let the live stream load.
  2. Tap on the Settings icon, then tap Advanced Settings.
  3. If the Record sound option is toggled on, tap to toggle off then back on.
  4. If the Record sound option is toggled off, toggle the switch on.
  5. If there is still no sound on the recordings, factory reset the camera and set up the camera again.
Alexa cannot discover or connect to my Wyze Cam Pan.
Here are some steps to try if your Amazon device is having trouble discovering the camera:
  • Ensure that the Amazon device is compatible with the camera. It must be an: Echo Show, Echo Spot, Fire Tablets and Fire TV. It’s compatible with all generations of Fire TV, all Fire TV Edition Smart TVs and Fire Tablets Gen 7 and above.
  • Ensure that your camera is updated to the latest firmware version.
  • Ensure your Alexa devices’ firmware is also up to date
  • Ensure that you authorized the correct Wyze account to your Amazon Alexa account.
  • Disable and re-enable the Wyze skill.
  • Ensure that the camera is connected to Wi-Fi by checking if you can load a live stream view of the camera in your Wyze app. If you are unable to view a live stream view of the camera in your Wyze app, see Connectivity troubleshooting here.
  • For additional troubleshooting, click here to refer to Amazon Alexa support.
My Wyze Cam Pan's microSD port is bad.
Problem:
You suspect you have a bad microSD port on your Wyze Cam Pan v2; the camera doesn't detect the microSD card, or doesn't back up correctly.
Troubleshooting Tip:
If you suspect you have a bad microSD port, check the contents of the microSD card on a computer to make sure that the card itself isn’t corrupted. If it is, try reformatting the microSD card and testing it in your camera again.
How to Format your microSD card
There's static noise when viewing to the live stream on Wyze Cam Pan v2.
Problem:
There is a static, crackling noise when viewing / listening to the live stream.
Troubleshooting Tips:
  1. Check that your Wyze app and firmware are up to date.
  2. Power cycle the camera by unplugging it from power, then plugging it back in.
  3. Try to factory reset your camera.
  4. Try to flash the firmware to an earlier version if you have a 32 GB microSD card available.
What ports are necessary for Wyze Cams to operate?
In most cases, home users will not need to manually change ports. If you are on a business/enterprise network your IT department can manually open the ports needed.
Here is a list of the necessary ports:
Port
What it does
What it's used for
TCP: 80
Local time lapse download
Timelapse
TCP: 123
Internet time check
Confirming the camera's time zone
TCP: 443
Cloud data transfer
Uploading Events
TCP: 8443
Cloud API
Keeping the connection with Cloud server
TCP: 8605
Upgrade package download
Firmware Upgrades
TCP: 10001
P2P streaming connection
Local live streaming over Wi-Fi
TCP: 10002
LAN firmware upgrade
Firmware Upgrades
TCP: 22345
TCP control
Making sure the connection stays open when viewing the Live Stream
UDP: 80
Heart beat & streaming data
For all UDP ports: Loading the Live Stream and keeping the connection between camera and server even when it's not actively being used
UDP: 443
