Can I add different Wyze Mesh Router models to my network?
No, you cannot add different mesh routers to the same network.
If you have both Wyze Mesh Router and Wyze Mesh Router Pro, choose only one type to install. They cannot be mixed and matched. To ensure the optimal coverage, capacity and performance, Wyze Mesh Routers will work only with other Wyze Mesh Routers in its same family.
