Yes, though we recommend you replace your old router with a new Wyze Mesh Router. In some cases, your ISP may provide an all-in-one router and modem combo that cannot be replaced.
To use your new router with your existing router:
- While going through the setup process for Wyze Mesh Router, connect your new router to your old router using the included Ethernet cable.
- During setup, make sure the Network Name (SSID) of your old router and new router are exactly the same.
- You're all set!
