How do I access my router's local UI?
To access the root Wyze Mesh Router's UI:
In your web browser, visit www.wyzerouter.com (or 192.168.50.1). The username and password are printed on the label on the bottom of the router.
đź’ˇ Tips:
  • The root router is the only router you can access. This address is always wyzerouter.com.
  • If you have Manual DNS enabled on your router, you will need to use 192.168.50.1 to access the local UI.
IMPORTANT: If you are seeing this page after typing in the above addresses, it means you are not connected to your router's network. To access your router’s local UI, you must be connected to your Wyze Mesh Router’s network (via Wi-Fi or Ethernet).
Still need help?
