How do I delete a Wyze Mesh Router?
To delete the root Wyze Mesh Router:
  1. In the Wyze app, tap on your Wyze Mesh Router.
  2. Tap on the Settings gear, then Advanced Settings.
  3. Scroll to the bottom of the page. Tap Factory Default and Delete and confirm.
Note: Deleting the root mesh router will also delete all satellite routers paired to the root router.
To delete a satellite Wyze Mesh Router:
In the Wyze app, tap on your Wyze Mesh Router, then tap on the satellite router you want to delete. On that router's network home page, tap Remove Router.
