Problem
Wyze Cam v3 Pro's status light is solid red, but you're not recording an Event, watching the Live stream, and haven't just plugged in the camera.
Troubleshooting
- Make sure you're using the USB cable and power adapter included with the camera..
- Try another USB cable and power adapter (only the adapter included with Wyze Cam v3 Pro).
- Power cycle the camera by unplugging it from its power source for 5 seconds and then plugging it back in.
- If there isn't power at all, try a different outlet.
Send a log from the Wyze app.
- Note the Log ID.
- Factory reset the camera and set it up as a new device. (Only do this after sending a log first!)
