How do I power cycle Wyze Cam OG?
To power cycle your camera:
  1. Unplug Wyze Cam OG from its power source. This can be done either from the power outlet, or from the camera itself.
  2. Allow 5-10 seconds to pass for the camera to completely discharge.
  3. Plug the camera back into the power source and allow it reinitialize.
Additional Note:
Power cycling refers to fully powering an electronic device off, usually disconnecting it from any source of power. This is a useful troubleshooting tool because it helps reset the device and its connections.
