My Wyze Cam OG isn’t detecting motion as expected.
Problem
Your Wyze Cam OG does not trigger for some motion events or is not detecting motion as expected.
Troubleshooting
    3. Compare your app version to the latest app version listed here on our Release Notes & Firmware page.
  2. Check that your Wyze Cam OG’s firmware is up to date.
    2. If there is an update available for the camera, please move forward with updating it.
  3. Ensure the camera is set to record correctly.
    1. Navigate to the camera’s settings > Event Recording.
    2. Enable Motion then select All Events.
    3. Tap Customize Detections.
    4. Next to Other Motion, ensure that the boxes are checked for both the Tag and Notify columns.
    5. Attempt to trigger the camera by creating movement in front of the device.
    6. Note: For Cam Plus users, once recordings for Other Motion are being generated, you can select the desired AI recordings by checking the other options in the Tag and Notify columns.
  4. Adjust the camera’s Detection Settings.
    1. In the Wyze app, go to the camera’s settings > Detection Settings.
    2. Under Motion Detection Sensitivity, adjust the slider bar to 100 while testing.
    3. Tap Detection Zone and toggle it off while testing.
  5. Power cycle the camera by unplugging it from its power source for 5 seconds and then plugging it back in.
  6. Factory reset the camera and then set it up as new.
    1. Remove any microSD card inserted in the camera.
    2. With the camera plugged into power, press and hold the setup button on the bottom of the camera for 10 seconds until the status light on the front of the camera turns solid red.
    3. Once the status light starts flashing red, set up the camera as new.
