How to factory reset your Wyze Cam OG
Use these steps to factory reset both Wyze Cam OG and Wyze Cam OG Telephoto 3x.
To factory reset your camera:
  1. Remove the microSD card inserted in the camera if there is one.
  2. With the camera plugged into power, single-press SETUP on the bottom of the camera for 10 seconds. The status light on the front of the camera lens will turn solid red.
  3. Once the status light starts flashing red, it's ready to be set up again.
