My Wyze Thermostat’s display screen is not functioning correctly.
Problem
Your Wyze Thermostat’s display screen is showing lines on the display screen, or the display screen is freezing or glitching.
Troubleshooting
Please be sure to always turn off the breaker before handling any wiring.
  1. Confirm your Wyze app is up to date.
  2. Check that your Wyze Thermostat’s firmware is up to date.
    2. If there is an update available for the thermostat, please move forward with updating it.
  3. Power cycle your Wyze Thermostat.
    1. Turn the breaker off for about 30 seconds.
    2. Turn the breaker back on.
  4. Factory reset the thermostat and set it back up like new.
    1. Press and hold the control wheel for 10 seconds.
    2. The thermostat will display a question. Turn the wheel to select Yes then press the control wheel to reset.
    3. Walk through setting up the device like new in the Wyze app, including redoing the wiring.
