Connectivity Troubleshooting
Problem
Your Wyze Cam Floodlight Pro is showing as offline in the Wyze app.
Troubleshooting
  2. Check that your Wyze Cam Floodlight Pro’s firmware is up to date.
    2. If there is an update available for the floodlight, please move forward with updating it.
  3. Verify that Location Permissions are enabled for the Wyze app in your phone/tablet settings.
    1. Make sure that it is set to Always or While Using the App.
    2. For iOS, make sure that Precise Location is turned on.
  4. Power off the floodlight by switching the breaker to the off position.
  5. Check all wiring to make sure it is secure.
  6. Make sure that Wyze Cam Floodlight Pro was installed properly by following the steps in our Wyze Cam Floodlight Pro Installation Guide.
    • If you’re ever unsure when dealing with wiring, we recommend reaching out to a licensed electrician at your discretion.
  7. Power on the floodlight by switching the breaker back to the on position.
  8. Confirm whether the status light is on after powering up the floodlight.
  9. Ensure that Wyze Cam Floodlight Pro has a good signal strength.
    1. You can check this in the Wyze app by going to the floodlight’s settings > Device Info > Signal Strength.
    2. If it has less than 2 bars, try moving the router closer to the floodlight.
  10. Reboot the router.
  11. Refresh the Wyze app's connection.
    1. Force close the Wyze app.
    2. Turn off mobile data on the user's phone/tablet.
    3. Wait a few minutes, and then turn the mobile data back on.
    4. Reopen the Wyze app.
  12. Power cycle Wyze Cam Floodlight Pro.
    1. Switch the breaker to the off position.
    2. Wait 5-10 seconds.
    3. Switch the breaker back to the on position.
  13. Factory reset Wyze Cam Floodlight Pro.
    1. Remove any microSD card inserted into the floodlight.
    2. With the floodlight powered on, press and hold the setup button on the back of the camera for 10 seconds until the status light on the bottom of the camera turns solid red.
    3. Once the status light starts flashing purple, set up the floodlight like new.
      • Try connecting to a 2.4 GHz Wi-Fi network when setting up the floodlight again.
