My Wyze Video Doorbell v2 is missing or not recording events.
Problem
Wyze Video Doorbell v2 is frequently missing events or there are no events recorded.
Troubleshooting
  2. If possible, check that your Wyze Video Doorbell v2’s firmware is up to date.
    2. If there is an update available for the doorbell, please move forward with updating it.
  3. Ensure the doorbell is set to record correctly.
    1. In the Wyze app, navigate to the doorbell’s settings > Event Recording.
    2. Enable Motion then select All Events.
    3. Tap Customize Detections.
    4. Next to Other Motion, ensure that the boxes are checked for both the Tag and Notify columns.
    5. Attempt to trigger the doorbell by creating movement in front of the device.
    6. Notes:
      • For users who do not have a Wyze Services subscription enabled, there will automatically be a 5-minute cooldown period between thumbnails.
      • For Wyze Services users, once recordings for Other Motion are being generated, you can select the desired AI recordings by checking the other options in the Tag and Notify columns.
  4. Verify that the Detection Settings are set correctly.
    1. Navigate to the doorbell’s settings > Detection Settings.
    2. Under Motion Detection Sensitivity, adjust the slider bar to High.
    3. Tap Detection Zone and toggle it off while testing.
  5. Verify that there are no Automations set up that could be causing interference.
    1. Navigate to the Home tab of the Wyze app, tap Automations.
    2. Note: We recommend deleting any Automations and then adding them back one by one while testing.
  6. Power cycle Wyze Video Doorbell v2.
  7. Flip the breaker switch that is powering the doorbell to the off position, wait 10 full seconds, then flip the breaker switch back to the on position.
  8. Factory reset Wyze Video Doorbell v2.
    1. Remove any microSD card inserted into the doorbell.
    2. To remove the doorbell, press the doorbell in and slide it up before pulling away from the wall plate.
    3. With the doorbell powered on, press and hold the SETUP button on the back of the doorbell for 15 seconds until the status light turns solid orange, then release the setup button.
    4. Once the status light begins flashing orange, set up the doorbell like new.
