My camera is not a chime option for my Wyze Video Doorbell v2.
Problem
Your Wyze Cam is not listed under the accessories section of Wyze Video Doorbell v2.
Troubleshooting
  1. Verify what type of Wyze Cam you are trying to use as a chime.
    • Currently, only the following Wyze Cams can be used as a chime with Wyze Video Doorbell v2: Wyze Cam OG, Wyze Cam OG Telephoto 3x, and Wyze Cam Pan v3.
  2. Confirm that your Wyze app is up to date.
  3. If possible, check that your Wyze Video Doorbell v2 and compatible Wyze Cam's firmware is up to date.
    2. If there is an update available for the doorbell or camera, please move forward with updating them.
  4. Check that your compatible Wyze Cam is set up in the Wyze app and the audio is working normally.
    • You can try enabling the siren or using 2-way audio to test this.
  5. Ensure the camera is set as the doorbell’s chime.
    1. Navigate to the doorbell’s settings > Chime Menu > Cam as Chime.
    2. Select the camera you would like to use.
  6. Restart Wyze Cam OG.
    1. Navigate to the camera’s settings > Restart Device > tap Restart.
  7. Restart Wyze Video Doorbell v2.
    1. Navigate to the doorbell’s settings > Restart Camera > tap Restart.
