How do I factory reset my Wyze Band?
To reset your Wyze Band from the Wyze app:
  1. Open the Wyze app and tap Wyze Band.
  2. Scroll down to the Settings screen. Tap Reboot Device.
To reset your device info from the band itself:
Tap on the Wyze Band screen to wake it up, then scroll and tap Setting Reset. Confirm that you want to reset the band by tapping OK.
Still need help?
