My Wyze Band settings won't save
Check the app version
Check the app store to make sure there isn't an update available for the Wyze app. It's always best practice to make sure you have the latest version installed to ensure the setup goes smoothly.
Cycle your phone/tablet's WiFi and Bluetooth
Before trying anything else, turn off your phone or tablet's WiFi and Bluetooth, then turn them back on. This should help make sure it's communicating properly.
If using a Motorola device, ensure that you have GPS enabled as some Motorola devices require GPS be enabled for Bluetooth to function.
Power-cycle your phone or tablet
Similar to toggling the WiFi and Bluetooth, turning your phone off/on can help make sure it's communicating properly with both the Gateway and the network.
Make sure your Band is charged
A low battery can interfere with a number of functions. We recommend charging your Band back up to at least 50%+, then try trying again.
Reboot your Band
From the Band’s product page in the Wyze app, go to Settings by selecting the gear icon from the list, then tapping on the screen mirror. Tap Reboot Device and wait for your Band to finish rebooting.
