My Wyze Band is not connecting to the Wyze app.
Problem
You're trying to connect or pair your Wyze Band to the Wyze app, but it isn't working. The connection fails 😞.
Troubleshooting
Wyze Band uses a Bluetooth connection only, not Wi-Fi. If you're having connection issues, give these steps a try:
  1. Force close the Wyze app, then reopen it.
  2. Turn off your mobile device's Bluetooth connection, then turn it back on.
  3. Navigate to the Wyze Band screen in the app and wait for it to sync.
  4. Tap on the band to activate it. Do you have the Bluetooth not connected icon on the screen?
    • If not, your Wyze Band is now connected to the app. Hooray!
    • If yes, continue to the next step.
  5. Reset your Wyze Band if you are still not connected to the app via Bluetooth.
Additional Notes:
  • Keep the Wyze app running in the background at all times. It needs to be open to transmit data via Bluetooth, for functions like Alexa and Shortcuts.
  • If you have multiple versions of the Wyze app installed on your device, close them. Keep the Wyze app you use most often open.
  • Are you on iOS? Turn on Location Services and keep it enabled.
If you're still having issues, submit a log from the Wyze app. Go to Account > Wyze Support > Submit a Log and send a detailed log for our engineers. Be sure to include any other Wyze devices you own that use Bluetooth. Then, reach out to Wyze Support using our chatbot for more help.
