All Wyze devices have a handy status light that helps determine what state the device is in. You'll find the status light on the front of your Wyze Video Doorbell. No light? Make sure it's properly connected to power using the Setup Guide.
Status Light Guide Detailed
Wyze Video Doorbell
- Solid yellow light: The device is powered
- Flashing yellow light: Waiting for connection
- Flashing yellow/blue light: Connecting to router
- Flashing blue light: Connecting to external network
- Solid blue light: Connected
- Flashing blue/purple light: Doorbell has been pressed
- Solid purple light: 2-Way Audio is active
- Flashing white + LED on: Person detected
Wyze Chime
- Flashing blue light: Connecting to network
Troubleshooting your status light after the doorbell has been set up.
- Factory Reset: Press and hold the reset button until the light stays yellow. It will remain yellow during setup / device reboot.
- Flashing blue light: Doorbell is disconnected from server
- Flashing yellow and blue: Internet connection issue
- Flashing yellow: Extended internet connection issue
